Skip to main content
Change location reference and technical label
Location reference​
  • You enter the location reference while ordering the location in Order Management.
  • It is displayed in the Enterprise Connect Dashboard, but it can only be changed in Order Management by changing the location profile in Order Management:
  1. Order Management
  2. Administration
  3. Inventory & subscription
  4. Select the appropriate Enterprise Connect Agreement
  5. Tile Locations
  6. Right-click on the corresponding location and select Enterprise Connect [XS/S/M/L] change:
Technical label​
  • You can assign and change the technical label directly in the Enterprise Connect Dashboard.
  • Both labels can be searched for in the location search box and the device search box.
