WLAN: Wide Channel Band settings
- You can find these functions under the corresponding Access Point at a location in the Dashboard.
- Select a band to place the access point in corresponding channels (wideband).
- The wideband channel band allows you to configure 20MHz, 40MHz, or 80MHz channels in the 2.4GHz and 5.0GHz bands.
- Save the setting and submit the cart to activate the settings.
